Referral issue
Mossmyster
  • I went out and purchase a new SIM card and help my friend set up his account but the referral section didn’t get filled properly .  How are we able to fix this.  This was the entire reason I went and purchased and set up my friend for the referral honus
Yes all reports seem to be that if a referral code doesn’t work or wasn’t used Initially, the moderators will add it for you without a problem.
AE_Collector
Spudster
Hi @Mossmyster
After the activation, your friend can message a Moderator to have the correct referral code entered and they will honor it.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator, then select contact us, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
Oracle365
Sorry to hear this. I would contact a moderator (set up a ticket).
