Referral Code
MelBel
How do I know the referral code worked? When I typed it in on activation it had a check mark beside it but I don't see a mention of a $10 credit anywhere. I also used the extra data code as well it seemed to have worked.
2 REPLIES 2
@MelBel you can also check to see if the person's code you used is showing on their Self Serve account, the $1 usually shows up right away on the referrer's account.
Your last four digits of your phone number should be listed under their 'My Rewards' section.
Clicking on the arrow pointing to the right, which will open up the list and the arrow will then point down:
Triguy
It can take up to 72 hours for the credit to appear in your account.
