Referral Code
Wanda0956
Hi,
I was given a referral code from a friend, but it wouldn't work when prompted to enter it.  I also tried using the the referral code link that was sent to me by my friend and that didn't work either.  I had to move on and activate my new plan without entering the code.  Is there some way to have the referral code applied now?
Thanks,
Wanda
2 REPLIES 2
maximum_gato
@Wanda0956
Yes you can as per the link provided by @hairbag1. Do you know the last 4 digits of your friend's phone #? If so supply them along with the referral code so that the CSA can confirm they are using the correct referral code and your friend will earn their 1pt/$1 per 30 days that you are an active customer. You will see the $10 credited to your account within the next 72 hours but likely it will be added by tomorrow afternoon.
Welcome to Public Mobile!
hairbag1
