Refer a friend.
CRW
Does anyone know how long it takes before you see the Refer A Friend points on your account?
2 REPLIES 2
@CRW  if you are the one who just joined with an referral code, you will see the $10 as a credit showing up in Available fund within 72 hours
However, if you are the one referring your friend to join PM, it could take a bit longer for you to see the friend referral on the My Rewards portal.  If you are worry, ask if your friend got the $10 in his/her My Account's Available Fund.  If you friend sees it, then no worry, the point will show up on your side soon.
JRod
I believe it takes 48-72 hours to see the rewards on the account.
