08-12-2023 05:20 AM - last edited on 08-12-2023 02:21 PM by computergeek541
I referred a friend xxxxxxxxxx xxx xxx xxxx with my referral code on 8-10-2023
& still haven't received my reward.
Somebody please resolve this issue.
08-12-2023 12:42 PM
If this is the case, both of you should contact a CS_Agent then.
In the past, new members have been entering the wrong referral code. Mixing up O with 0, I with 1, S with 5. This could be the case.
08-12-2023 11:37 AM
@GDOGP You need to get your friend randy to submit ticket with support to ensure the code was entered correctly
private message To CS_Agents click
VVVVV Link below VVVVV
08-12-2023 11:35 AM
No, the award is not in my account, nor did I get a cha ching text
08-12-2023 11:00 AM
Didn’t you asked the same question yesterday?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Refer-a-friend/td-p/1032188
Did You read the responses?
If your Rewards is in your account, your friend will receive his credit tomorrow. Remember, this is a credit that will apply to their next bill which will be 27 days away.
08-12-2023 05:28 AM - edited 08-12-2023 05:30 AM
@GDOGP . Please remove personal info this is public forum. Did your friend get the $10 credit with in 72 hours after activation z you should see yours almost immediately did you get the cha ching text ? . After 3 days have your friend contact support to make sure the code was applied correctly
