Refer-a-Friend Add on
bradp36
I just received my 1 GB add-on for referring someone yesterday and it is being used over my normal data for some reason. I have have nearly two gigs of data remaining for my billing cycle so I don't understand why this is happening. Can anyone help me out? Anyone else experiencing this?
j0nf
I got the exact same issue after receiving my free 1gig yesterday.
bradp36
PMed a mod and had it fixed pretty quickly. This isn't how the add on is supposed to work so if you have the same problem I suggest you do the same!
Edit-It wasn't fixed. My bad as I misunderstood the Mind's message. He did a temporary fix but there has been a ticket opened to solve the problem.
Shazia_K
Retraité / Retired
Retraité / Retired
@NDesai,
Technically, this shouldn't be the process but I will investigate on this.
Thanks for letting us know & I will update.
Shazia
@Shazia_K or @MarieHelene_L ???
NDesai
Oh oh, this shouldn't happen.
@Mary_M or @CS_Agent Can you confirm if this is the way this add-on suppose to work or if there is anything wrong?
