Refer Code
ellanaccarato
I just joined Public Mobile with a referral from a friend but didn’t have their referral code.
I now have their code, would I be able to give th
2 REPLIES 2
maximum_gato
@ellanaccarato
Yes most likely....it helps if you supply the last 4 digits of their phone # so the CSA can confirm the correct code is being used as once added they cannot be removed. Contact customer er support as provided by @hTideGnow.
HI @ellanaccarato
it might be possible.  Please submit a ticket with PM agent and ask
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
