03-13-2025 11:11 AM
Hi
I found the catalogue but I just want to use my points towards paying a bill. What are the steps? Thanks
a month ago
Thanks very much!! cheers,
03-13-2025 11:19 AM - edited 03-13-2025 11:21 AM
Hey, it's easy.
Once your on the catalog, scroll through the list. For 15 points, you get $15 off your bill. It will let you know if you have enough points. Click redeem. Then confirm, yes agree and presto! An email will be sent. You can continue to redeem in increment of 15 points untilyoudont have enough. The funds will go to Available funds which will be taken from your balance on next renewal. Any left over amount will remain until used up. Your credit card will not be charged if you redeem enough to cover your plan.
03-13-2025 11:12 AM - edited 03-13-2025 11:15 AM
Go to My Rewards then Browse Catalogue and there you will see conversion to funds available.
