10-07-2025
12:26 PM
10-08-2025
12:55 AM
computergeek541
Good morning, my question is concerning the recurring payments of an unfinished plan. You see, I bought the SIM and went thru all the steps, but got hung up on the number transfer stage. Then I didn't have any signal or data at all from PM, so I switched back to my old Telus SIM and my normal signal returned. So, since my activation couldn't be completed, will I still be charged a recurring fee for the SIM card that is not in use?
10-07-2025 12:30 PM
hi @Big_Tex
if you "hung up" on the phone number stage, the activation was not completed. But PM support agent can assist to complete it, or they can provide refund if they cannot help
you can submit ticket by direct message:
10-07-2025 12:29 PM
you can ask PM to help to complete your activation
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
