Receiving calls on public mobile phone
prateekpannu
Hello,
Not sure if other people also experence this but when when some one calls my number, they first get notified that their call is being forwarded.
Which dosnt make sense, when someone calls me they should either be connected directly or if forwarding is necessary, there should be no need to notify the person calling
2 REPLIES 2
stonechucker
Forwarding should not be required at all.  Have you got something programmed into your call forwarding settings on your device?
will13am
@prateekpannu, are you using some kind of call forwarding?  I don't recall seeing anyone mentioning this as a bug in the system in the past.  Certainly that's not how the system works.
