08-26-2019 10:52 AM - edited 01-05-2022 06:39 AM
How can my friends call me from outside Csnada? I sent them my cell number and added +1 before it. However it give them message it is not correct number ! can you help me please
08-26-2019 05:00 PM
@khhassan wrote:yes ... it works within canada and I receive/ make calls from/to all provinces
A call could come from anywhere and it would not make any difference for the person receiving the call.
08-26-2019 11:43 AM
08-26-2019 11:41 AM
@khhassan wrote:since it cell number, there is no area code I think!
they used the exit code + then Canada code 1 then my ten digit cell number.
Even they tried 00 as exit code instead + but it did not work !!!!!
The first 3 digits of your 10 digit number is your area code. The next 3 digits is the prefix. It's only really the last 4 digits that are your number (one could say only the last digit too 🙂 )
Can you call your number from here?
Can they call to Canada?
08-26-2019 11:38 AM
08-26-2019 11:30 AM
00-1-10 digit mobile phone#
Follow the dialing format shown above while calling Canada From Kuwait.
08-26-2019 11:27 AM - edited 08-26-2019 11:29 AM
@khhassan wrote:I asked two of my friends to call me from different two countries in middle east ( Egypt and Kuwait) their plans allow them to make international calls to everywhere and they added +1 before my ten digits cell number but it give them message in their local language (Arabic) that it is not correct number !!!!!
Maybe they need to use the full exit code rather than the +.
00-1-your 10 digits
08-26-2019 11:25 AM
08-26-2019 11:19 AM - edited 08-26-2019 11:22 AM
@khhassan wrote:How can my friends call me from outside Csnada? I sent them my cell number and added +1 before it. However it give them message it is not correct number ! can you help me please
It's the same international dialing as it has been for decades.
Countries have what's called an exit code. Canada/US is 011. Countries will have a country code. Canada/US is 1. Then usually there would be an area code like say 416. Then the persons number.
Using the + (plus) will usually work instead of the exit code.
But of course they need to be able to make that international call. If their plan doesn't allow it then of course they can't call you.
@token: "ever" is a broad word. Currently we can accept calls from anywhere. There are no extra charges here.
08-26-2019 11:18 AM
When dialling international numbers from Europe (like from Spain to Canada for example)
need to dial the originating country's exit code, (00 in spain) then the
country code for the destination (1 for Canada) then the ten digit
number inside Canada (3 digit area code plus 7 digit number).
A related question is whether Public Mo will ever chage any fee for
any incoming call (from abroad) while in a normal coverage area??
08-26-2019 11:10 AM
If you have another phone or landline. Have your friend try to call to see if it works then it could be an issue your cellphone.
08-26-2019 11:07 AM
Thanks
08-26-2019 10:56 AM
Seems more likely an issue at your friend's end. Adding 1 as the country code to your number when dialled internationally is correct. Maybe ask your friend to check for international phone call requirements from their end.
