Received a Message, not enough credit.
aj6
Hello Friends,
I set up an auto payment on my account; and my AMEX credit card was charged on 29 Dec, with the next withdrawal date being 28/January. But I have not been able to make call since, with my account saying "not enough credit." Please what do you think is the problem?
Sincerely,
AJ6.
11 REPLIES 11
@aj6  Please login to your account:
- follow @Anonymous 's suggestion to check your SIM card number
- review your Payment history to confirm autopay is working and your account is Active
- confirm your credit card has not expired
aj6
No, I can't. The message says, "not enough credit to make this call." Thanks.
@aj6 wrote:
No, I can't.
Can you log in to your self-serve account? If so, what is the status? Active? Plan Expired?
Can you click into Change SIM and take note of the last 4 digits of the registered SIM card and then compare that to your actual one in your phone? Are they the same?
aj6
When I tried calling, and also people have told me that it goes straight to voicemail when they tried calling me.
aj6
I will try calling 611. Thanks for your help.
aj6
No, I can't.
@aj6 wrote:
I have the $25 plan. Thanks.
Can you take calls? Text in/out? Internet?
Edit: Could you transcribe the exact wording?
aj6
$25 plan. When I tried calling, I get a message saying not enough credit.
aj6
Luddite
What plan do you have?
Can you call 611?
 @aj6 : When/where is/does it say that? Are you on the $15 plan?
