Receive a new simCard
mgrenier
The Sim card is not fonctionnal...
8 REPLIES 8
mgrenier
Thank-you !
It worked !
Marc
mgrenier
OK ! Thanks... I'll try it...
Dtack
If you want to order a new Sim Card you can order through Public Mobile directly, Amazon, Canadian Cell Supplies or a lot of local suppliers sell them - London Drugs, Esso, Superstore, just check in your area. Good luck!
@mgrenier  your IPhone is probably locked to the previous provider. Contact them and ask them to unlock it for you.  You will need your imei number dial *#06# to get it.
Also sync to iTunes
1. Insert new working SIM - do not turn phone on (if SIM is already in, turn off)
2. Connect to computer with USB cable.
3. Start iTunes if it doesn't auto run
4. iPhone will switch on. Wait until iTunes registers it and checks for updates
5. Install the carrier profile update (if offered, if not, go to step 6)
6. Disconnect and restart. From @luddite.
mgrenier
Receive a new simCard i should have write : how to Receive a new simCard. Sorry !
mgrenier
Thanks, but the sim is not new. We try to put it on a non locked iphone 6s. But it says no sim...
gblackma
@mgrenier is this a new activation?  How far did you get in the process? Check to see if your credit card as charged. Insert your SIM into your phone and try to log into your self service account.
If it wasn't. Wait 50 minutes from last attempt, go to private/ incognito mode and try again to activate your SIM card.
Here's 3 articles on activation and porting and the Refer a friend reward  if you need them:
1.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
2.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
3. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
RossN
@mgrenier what if any messages are you getting? what type of phone is it unlocked?
