05-26-2021 01:14 PM - edited 01-06-2022 02:09 AM
05-30-2021 10:06 PM
05-26-2021 01:33 PM
Virgin. You have to activate with them if you want to try getting the number. You might want to go to Virgin Kiosk to see what "magic" they have 🙂
also, you tried to call you number? If someone picks up, then the number is "gone"
05-26-2021 01:31 PM
Actually originally number was from virigin mobile than later it was transfer to bell than public mobile. So where I can contact.
05-26-2021 01:27 PM
@Nakib91 if your PM account suspended for over 90 days, then no.
Numbers like this will go back to the original provider. For example, if the number was originally Rogers and ported over to PM, the numbers will return to Rogers
You can try to find where the original provider the number belongs to and try, but it's hard unless you know someone.
