11-03-2023 09:44 AM
11-03-2023 09:48 AM
did you just join PM and requested porting your number into PM ?
If you are porting your number, did you reply a text to your old provider and reply YES within 90 mins? If you miss that, the porting was not completed and hence you are not receiving incoming calls. There is a number you can call to talk to live support and re-trigger the process. I will message you the number, please check your Community inbox, envelope icon on top right
if you are not new to PM, incoming calls and text were working fine before and just not working now, try to :
