Re: promotion honoring request
12-05-2016 10:21 AM - edited 01-04-2022 01:21 PM
Thank you @Luddite, I hope a moderator would be able to help, i just messaged a moderator this weekend, I believe there is just a handful of people and they must be very busy.
@Jeremy_M, could you also look at my plan activation/phone number porting? I did it all at once, but I guess it hasnt completed, as I can only call out, but cannot receive calls or have access to my data.
Thanks,
Joining Public
12-07-2016 03:50 AM
12-07-2016 02:31 AM
12-07-2016 02:02 AM - edited 12-07-2016 02:02 AM
@Luddite, do you know of a responsive MOD who can assist? I lost connectivity with my old SIM, I am stuck with no connectivity either from the old company, or public mobile, I really need to get connectivity ASAP.
please tag anyone who you'd think can help, I can then sent them a private message with any details they might need.
Thanks,
12-06-2016 11:19 AM
@Luddite I requested phone number porting when I activated my SIM, it gave me a few issues while trying to configure AutoPay, but ultimately that part worked, yet number porting is not enabled yet, and since I didnt chose a number, I can't really use it until phone porting and activation is completed.
@Rockdaddy22, I tried the activation on Dec 2, so that would be 4 days.
12-05-2016 11:41 AM
12-05-2016 11:33 AM
@jrniebla I moved this particular post because it is a different issue.
You are already in the queue for port-in problems if you followed this procedure: Contact moderators. The backlog is such that it may be several more days before you have a response. Suggest you create a way to cope with that delay.
While you are waiting some people have found this procedure helpful: http://productioncommunity.publicmobile.ca/t5/Discussions/How-I-fixed-porting-my-mobile-number-and-p....
Also, try your old SIM. If it works just keep using it until the PM SIM is functional. Do not close your old account; that will happen automatically. Or if you have another phone, use your old SIM in it and carry on with two phones.
Let us know if you lose service altogether.
