Re: my text doesn't work
Ug33
I'm a new customer and don't
7 REPLIES 7
@Ug33 wrote:
I think so re the mobile data. And I can call out.
I did recently sign up and port my number.
@Ug33
Your port is likely stuck then. With stuck ports, you should be able to call/text out.  Unable to receive calls or texts.
Here is some more information about porting:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
You can either call Telus porting team or contact moderator for help.  I will private message you the phone number.  This number can only be used for porting issues
Ug33
 @Ug33 : So you can browse the internet using mobile data (not wifi for this) and you can call out. Correct? Did you recently sign up and transfer your number in?
Ug33
I tried restarting the phone. That made no difference, I can't get or send texts, and I can't receive calls.
 @Ug33 : Click on the Reply button to the lower right of a post and then type in the larger text box...not the tags box.
So any texts? Both in and out? Maybe restart the phone?
Dunkman
@Ug33
A few basic troubleshooting advice:
Reboot phone
Network reset of phone
Toggle airplane mode on, then off.
P.S. I started your own thread.
 @Ug33 : Which phone are you using? How about calls in/out? Internet browsing? Which texts...in or out? Or picture/MMS?
