Re: add ons
laura25
I arrived in the USA on oct12/25 I purchased 1 in St John's NL before I left for my number.That was applied to my wife's phone. I have purchased 4 more add ONS since I arrived but none was applied to my phone. I would a refund for the add ONS that I did it receive.
2 REPLIES 2
CSA_PM
Customer Support Agent
Hello @ laura25,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@laura25
For the multiple add-ons purchased issue, you need PM CS agent to sort this out for you.
I have escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
But for addon usage, what add-on you got? Data ? or bundle or Calls?.
Critical part to US roaming depends on T-Mobile/AT&T/Verizon coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T/Verizon, change the Network Connection from Automatic to Manual and select and test each of the three and see which one you can connect and work best
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter.  Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting.  And if it does not work, try to change the Network to T-Mobile ONLY, and change  Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data  is working
