Re: Winnipeg Network Down 15-04-2026
Kitty162
I'm having same issue today I did the checks too. Network must be fown
1 REPLY 1
hi @Kitty162
you are in Manitoba? you are aware of the 3G shutdown? More details here:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
Your phone might not be on PM's VoLTE whitelist (you might have a 4G or 5G plan, but this is about device).  Use the IMEI checker to check:
https://www.publicmobile.ca/en/on/get-help/articles/volte
