Re: Winnipeg Network Down
SLI2908
If this is not starting until March 1st 2027 why are older phones having issues suddenly now? My LG velvet has worked perfectly fine with public mobile since I switched over in January. So it was compatible. Suddenly now it is not? Someone in another thread mentioned it started in March of this year so, which year is it really?
SLI2908
I know it's old but I love it. Have had zero issues and it works perfectly otherwise. 🙁 Just an unexpected large expense now.
LG Velvet is a 5 year old phone, it is not bad to start shopping for a new one as there is no more support from LG and the phone not getting more security patches
SLI2908
Thanks. All very frustrating, New to PM as  of January. Never got any notification that this was happening.
@samedi989
Winnipeg is not 2027. 2027 is for provinces other than Manitoba
if you read the post above, With Manitoba, they already started the decommission:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
Currently, the sunset has been initiated in Manitoba (Rural & Winnipeg / Brandon)
SLI2908
Winnipeg, Manitoba
slusagm
@SLI2908
which city and province you are at ?
