01-08-2021 07:56 PM - edited 01-05-2022 04:47 PM
wWhat APN settings am I supposed to use umidigi A9? Thanks for any assistance...
01-10-2021 08:38 AM
I have an UMIDIGI A7 Pro but I imagine other versions have the same internals re: the APN.
If the APN isn't automatically set up by default, to view your APN set up, or to change it, do the following:
From your Settings > Network > Internet & Mobile Network > Advanced Settings > Network
at this point you can choose to > Automatically select network (in my case PM)
or you can choose to > Access Point Names (in my case there are 3 additional choices + 2 options for further information)
Hope this helps. o/
01-08-2021 08:50 PM
@kidsgone wrote:wWhat APN settings am I supposed to use umidigi A9? Thanks for any assistance...
Public Mobile's official answer to that is at this link: Set up data on an Android phone (publicmobile.ca)
On some Android devices, you'll need to set the APN type to:
default,mms
