Re: Smart watch
naraghian
Hi, I just bought a Galaxy watch 4 LTE, so I had to retun it as PM does not support direct connect to smart watch.
So if you buy it only buy a version to pair to you phone not a sim or LTE or change your provider.
1 REPLY 1
@naraghian   the Galaxy Watch 4 needs eSIM and PM does not support eSIM
So, you are not happy with just pairing with the phone?
