Re: Service issue
ManjuPathak
I came for a work and now i am stranded with no service. This is serious. DID ANYONE FIND A SOLUTION??
7 REPLIES 7
ManjuPathak
Its an esim . After network reset there is no sim now
@ManjuPathak
try restarting your cell. Then try a network re-set. See if either suggestions help.
hi @ManjuPathak
when was the last time you were able to use the service?  Call 1-855-4PUBLIC using another phone and enter your phone number to confirm if account is active.
if active, ask PM agent to sort out the login issue
you can submit ticket by direct message:
ManjuPathak
When i log into the account. There is no information its like new account without subscription
ManjuPathak
About 6 months ago, when there was a promotion going on of 50%off. For a 2 years subscription. Suddenly today there is no service . When i try to make a call it says you don't have a plan. And proceeds to give me subscription plan
hi @ManjuPathak
please login My Account and confirm if service is suspended.  If it is, make a manual payment
if it shows service active, the Reboot your phone and click Reset network settings
Meow
More details are needed.
When did you subscribe? Did you try to reboot your ohone, etc. etc.
