Re: Required info to authenticate accounts
cecelia
I was asked by moderator Alex to download authentication form complete such and send
back to him so he can lok at my account.  I able to down the info so i replied with my
name, address,DOB and pin and have not had a reply since.  Phone not working since
Aug 19 said need data addon.  Any suggestions
Can you provide more information ?  What type of plan do you have ?  Are you trying to access the internet ?  Have you logged into your self serve account ?  Under data and add-ons - do you see any amounts.  If you have data on your plan but no amount showing then it means you have depleted your data.  In that case you would need to purchase can add-on for more data or wait until your next renewal date.
cecelia
Dunkman
@cecelia
Sorry to hear about your troubles.
If you have not heard back from moderator within 48 hours, you should send another private message.
