Re: Problem sending Picture messages after update
slauer26
hello ,
I have a kyocera duraforce E6910 with android 10 too and have the same issue with the MMS even when the Apn settings are correct.Only data works correctly
I have tried three different cards/carrier  with correct MMS apn settings and the problem still persists.
you see only the sending arrows which interrupts permanently.
I think there is a bug on their software or did you solve the issue with a workaround ?
Thank you
2 REPLIES 2
TheSterlinger
As far as I’m aware the is no work around. The only solution is buying a new phone that’s within the last 6ish years old.
https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
But trying changing your APN settings again. Click add new setting and remove old then add this. Restart and see if any change.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
@slauer26
It is an APN issue.  You will need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces.  Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
         (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
