10-18-2020 09:54 PM - edited 01-05-2022 05:17 PM
To all members of Public Mobile.
Its not a great service to have with phone plans.
My fiance had problems with them since she been with Public Mobile.
She got a 25 dollar voucher minutes worked not even 2 days that was all.
then they say no sim card it was brand new.
Now if they could reimburse the 25 back that be awesome but its will not happen.
Cause they are un refundable. Its not fair to the customer that phone does not work.
I think they rob customers of there minutes and time on phone.
Cheap yes but not very reliable service at any rate.
Payiing for a sercvice that is not trustworthy and customers should not be put in that position.Now had to go with another services provider just to dish out more money just to have phone working properly.
Do not use this service.
Sincerely
Disgrunted customer..
10-19-2020 12:37 AM
It's not fair, which is the reason I put very little stock into an online review of anything other than a company's interaction
10-18-2020 11:05 PM
@Mccafe_54 wrote:To all members of Public Mobile.
Sincerely
How is it “fair” that PM takes the fall for a customers phone that potentially isn’t working properly? Did you remove and reinstall the SIM card and reboot the phone before suggesting to us that we “Do not use this service”? Too late for me.
AE_Collector
10-18-2020 10:45 PM
Sincerely
When you are saying that the phone said no sim that makes me think it is probably more of a phone issue. Can you give us more details?
10-18-2020 10:13 PM - edited 10-18-2020 11:13 PM
Public Mobile service is exactly as reliable as Telus, Koodo, Bell, Virgin, and Lucky because they all use exactly the same network.
You are correct there's no refunds. The same as with every other prepaid carrier.
I'm guessing all these problems you (or your fiance) experienced are caused by a trying to use a PM SIM card in a carrier-locked phone. Or by some kind of activation problem.
This is easy enough to sort out. First login to Self-Serve to confirm your account, SIM card, and plan are activated.
You can file a consumer complaint with the CCTS if you like. But beware that they will dismiss any complaints which do not follow their own procedures, and the most important first step in these procedures is that the customer can prove "reasonable" attempts have already been made to communicate with the carrier to resolve the problem. The people on this forum are customers just like you, if you want to communicate directly with PM then you've gotta get a support ticket through the Simon chatbot or you've gotta send a private message to the @Moderator_Team
10-18-2020 10:05 PM - edited 10-18-2020 10:06 PM
@Mccafe_54 Public Mobile does not "rob" coustomers of their money. The issue your fiance was having can be solved through us or the support team.
Can you give us more info on your issue so we can try and assist you ?
I've been a happy public mobile customer for 9 months now without any issues or problems. Im absolutely loving it.
10-18-2020 09:59 PM - edited 10-18-2020 10:00 PM
Disgruntled customer:
Sorry to hear your experience. Many thousands of customers are going on without a care in the world that their service works as expected.
Perhaps if we'd had a chance to help you with the problems you mentioned you might have had a better experience. Or to have the moderator team have a chance to help you.
10-18-2020 09:58 PM - edited 10-18-2020 09:59 PM
Have you already activated with another carrier? If not, can you give us more details so we can assist you?
