Re: Not able to make or receive a phone call?
duncan_mccaul
My new phone is working intermittenly - sometimes I can make & receive phone calls, most times I can't and it tells me I am "not registered on network". Text is the same. I got a new Galaxy from Orchard, installed the sim that came with it, and registered online okay. Please advise. Thank you.
32 REPLIES 32
Grant_J
Try removing and reinserting the sim card, sometimes they aren't perfectly touching the contacts and you get that kind of issue. If that doesn't work a mod such as @Shazia_K can help check if something needs to be reset.
srlawren
Hi @duncan_mccaul, welcome to Public Mobile!
I've moved your post to it's own new thread, so it has better visibility.
It sounds to me like you may have received a defective SIM card.  Could you try powering off your phone, removing the SIM, waiting about 60 seconds, then re-insert the card and power back on, and let me know if that makes any difference?
