Re: Live Changes and Improvements to the Public Mobile App
Jack95
How come I can’t get the app on an IPhone?
dust2dust
@Jack95- There's a cut-off in OS version for the app. Which version is your phone on?
Jack95
Sweet, I’ll see what I can do
HI @Jack95
does your App store set to non-Canada?  You have to change it to Canada to download
if you don't want to , you can also ask a friend to help.  Your friend download the app and activate the account for you.
After the activation is completed, your can use the web to access everything instead
