Re: Cellular Data Not Working After Changing SIM Card
02-11-2020 03:11 PM - edited 01-05-2022 09:27 AM
Hello everyone, did anyone ever ending up finding a solution to this? Or do we just have to keep doing a factory reset each time without restoring the old profile? I'm experiencing the very same issue right now.
My Account
05-19-2021 02:44 PM
05-19-2021 02:11 PM - edited 05-19-2021 02:12 PM
Good question....I have no idea!
If its an iPhone then @LurganIeUk or @AE_Collector can help. If its Android then maybe @Anonymous can probably weigh in. They are all old enough to possibly have had an AOL account.🤣
05-19-2021 02:04 PM
How do you delete the AOW profile from your device?
02-11-2020 05:00 PM - edited 02-11-2020 05:09 PM
@Charles5 When you’re finished using your AOW Data SIM, you need to delete the AOW profile from your device before you swap back to your carrier SIM. Did you do that?
Also dial *#*#4636#*#* and review all the system info. any reference to AOW?
02-11-2020 04:49 PM
@Charles5 does the PM SIM work if you remove the at&t SIM and vice versa? Also, have you tried switching the 2 slim slots.? I found this post here that describes a problem with at&t and other Sims not working at the same time https://forums.oneplus.com/threads/dual-sim-issues.412363/page-4
@Charles5 wrote:It's a dual sim phone. The other SIM slot has AT&T but it doesn't have a data plan (only calling and texting). I've already removed that and tried - no luck 😞
02-11-2020 04:40 PM
02-11-2020 04:36 PM
02-11-2020 04:27 PM
OnePlus 5
02-11-2020 04:16 PM
@Charles5 what brand and model Android phone do you have?
@Charles5 wrote:I have an Android phone.
Yes, I've verified multiple times that the APN settings are correct.
I've performed Network Reset several times already.
But this explanation seems to make sense: "It turns out the profile for the other SIM card I was using (AOW) was still resident in the phone, even though it wasn't showing in the settings and had been deleted."
The big question is: is there a way of finding and getting rid of this corrupted entry without performing an entire factory reset?
02-11-2020 04:01 PM - edited 02-11-2020 04:02 PM
02-11-2020 03:27 PM
02-11-2020 03:18 PM
@Charles5 Do you have an iPhone as well?
