Re: Cant make any phone calls
10-22-2018 09:38 AM - edited 01-05-2022 05:57 AM
11-22-2020 03:04 PM - edited 11-22-2020 03:04 PM
@PaulineA wrote:I'm having the same issue. Cant make any calls even if it's a local call its saying I dont have a long distance plan.
@PaulineA Sometimes letting the message play fully will allow you to connect unless of course you are on a limited plan and then do as suggested and purchase the 500 mins add-on and also it's always a good idea to add +1 in front of practically all numbers these days. Most new phones, I believe, automatically save +1 in the contact list so most people don't hear the pre-recorded message you're hearing.
11-22-2020 02:57 PM - edited 11-22-2020 02:58 PM
Try putting a 1 in front of the number.
Are you on the $15 plan and out of minutes? If so you can buy a 500 minute add on for $5 that rolls over each cycle until consumed.
11-22-2020 02:50 PM
