RE plan expire 120 days when I added US Roaming
deep_gupta
Hi,
My account less than one month in with a 90 day plan says Account expired because of non payment. I paid nov 18th for the 90 days. Looked at some other posts and all answers were solved under PM. Looking to see if a mod has an answer to this.
- i had added a US romaing package for $20.00 on December 1st 2016 so when the funds were added for this it set up. Ive had this issue since I added and used the USA roaming. Please help me resolve this issue and I can provide screenshots as well.
Name Deeptanshu Gupta email ID: d****************shu******50@g****m
Please help me as I have had no reply for almost a week I have even sent a mail to the moderators and a msg on facebook messenger.
Thank you
14 REPLIES 14
Subbanator96
Sorry, forgot to put @crxvti in the last post.
Subbanator96
Hey sure, 🙂 i tried to buy the texting and talking add-on but it's not available through *611, and on the options thing it wasn't adding properly. That issue might have been fixed but I'm not sure. So i bought the texting and calling add-on seperately for $8 each. Also, had to manually select the T-Mobile network when I got there and had great service after that.
crxvti
@Subbanator96did you buy the bundle add-on or just a single feature?  Can you tell me more?
Subbanator96
@crxvti it only happens with certain accounts, I added the roaming no problem to two different accounts. The community has calmed down also, so I would expect a relatively quick reply if anything happens. I was very happy with the add-on so I would definitely recommend despite the possible problems.
crxvti
Hi all, is there a solution now?
I plan to buy the US data-only roaming add-on and am hesitated if I should go ahead.
Please suggest.
Smokeshow
Same issue here
Shazia_K
Retraité / Retired
Retraité / Retired
Hello @Johrobkoo
Can you please send me a private message with account related info?
Thanks,
Shazia
Johrobkoo
  @Shazia_K can you please help us please.  It looks like after adding US Roaming Bundle system says "Account expired because of non payment"  However, the plan is good until Feb 22 but it says it will expire for non-payment on Jan 4.  I have no idea how to post to moderator so hopefully this works.
Johrobkoo
We have the same problem.  Can you fix it for us?
Wonderful @Shazia_K
@deep_gupta, U are in Excellent hands.
Please Update us on the progress
Shazia_K
Retraité / Retired
Retraité / Retired
Hello @deep_gupta
I'm sorry to hear you have been having troubles with the US roaming package.
I will reply to you shortly.
Thanks,
Shazia
rkreddyb4u
Ohh this Issue looks like only MOD team can help - @Shazia_K can you please help
Subbanator96
You should edit that post right away and take out the personal information.
makkahn28
