RCS when roaming
12-30-2024 04:18 PM
Let's say I'm in Europe where PM roaming is not available. If I'm on Wifi, can I send to and receive from anyone worldwide if they have RCS enabled? Will it work on Android and iPhone now?
If so, would be nice if companies send 2FA RCS/SMS. Of course, would be nicer if PM starts supporting international roaming.
Service
12-30-2024 07:30 PM
hi @BKNS27 actually I can still receive some short code if I pay for lock in number
12-30-2024 07:28 PM
Good to know about the short code on TextNow.
When I signed up on TextNow about 3 years ago. I was able to get short code but not anymore.
I have the TextNow SIM and credit in my account. Just wonder if the SIM will support the short code?
12-30-2024 05:18 PM
RCS will work on wifi, but SMS will not. Most MFA codes I receive are still SMS unfortunately, though I can think of one that I deal with that does use RCS.
12-30-2024 05:18 PM
@BKNS27 wrote:I don’t think the 2FA code will be send through these apps.
@zaptor99 @BKNS27 I needed a 2FA SMS once when I was travelling in the Caribbean and using TextNow. Initially I could not get it. I had to subscribe to the monthly keep your number fee after which I received the code. Then I unsubscribed. May want to look into it here; https://help.textnow.com/hc/en-us/articles/1500002893921-Does-TextNow-Support-Verification-Codes
12-30-2024 05:09 PM
RCS/SMS should work on wifi. You can also use WhatsApp or TextNow app in Europe for free calling and texting but I don’t think the 2FA code will be send through these apps.
12-30-2024 04:26 PM - edited 12-30-2024 04:35 PM
@zaptor99 wrote:If so, would be nice if companies send 2FA RCS/SMS. Of course, would be nicer if PM starts supporting international roaming.
@zaptor99 I must be one of the few that doesn't have RCS turned on lol. It should work on wifi though. Instead of 2FA SMS a far better option would be companies use an authenticator app. Even Revenue Canada uses it now. No worries about where you are and if you can or cannot receive a @2FA SMS. As for extended roaming, we are with a 3rd tier provider......
