RCS is being enabled. Will using RCS count towards your data allotment?
mattdxb
Logic would dictate that RCS will count towards data usage since it's not much different than using WhatsApp or iMessage, for example but confirmation would be nice. Especially for times if sending large pictures or videos.
It looks like Telus is actively enabling RCS now on the network.
mattdxb
If that's the case then it's nice that it should work over wifi.
My brother doesn't enable his data unless he needs it. So RCS will work if he's on wifi and if he's not then RCS will just fallback to SMS/MMS.
I suppose the same plan limits still apply though. He's still on the old $10 plan. Even with RCS, I would assume the same 50 outgoing text limit applies.
jor123
As far as I know it does count toward your data usage and isn't zero rated.
ShawnC13
While I have had RCS for a while on my android through it had stopped and I see it is up and working again.  Will be interesting to see what the outcome is of this
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
mpcdesign
@mattdxb , I do believe you are right. Chances are internet data will be used instead of traditional text messaging.
