Question
baize
I need a mod to see why I have the 15 dollar plan with unlimte incoming calls but can't recivieve any more incoming calls. I know I'm at my limit for out going, but no incoming are recieved?
TheOldVR
The new $15 plan works great for my parents... gives them tons of time to call each other.
My Dad tends to accidently burn the data by updating apps... but I turned off data for Google Play which should fix that issue.
Yay PM!
stonechucker
The original $15 plan was available for a short period of time, and without a lot of detail, the plan changed somewhat quickly to the unlimited plan that is listed now.
*IF* you did not specifically sign up on the updated plan, you're still on the old plan.  All you need to do is go to your self-serve area, select change plan on the overview plan, then choose the listed $15 plan.  Schedule it for your next renewal, or pay immediately for a reset on the new $15 plan.
baize
Okay great! Yes I got it a two months ago I beleieve. Thanks for your help.
@baize  did you upgrade your plan a few months back when they changed it? if not do it foryour next renewal date ,you can also get the 500 minute canada wide add on for 5 bucks for the inbetween times when you run out it will be there until you use up all the minutes
hycm53
Contact moderator team for your issue:
When you click on Plan Details, is the unlimited incoming mentioned? If not then maybe you're on the original version of this plan.
