Question about 100GB plan
JadenT58
 Hi there, I’ve been wanting to switch to the 100GB plan.
Online, it shows the unlimited data perk. However, in self serve, it doesn’t show the plan as having unlimited slow data after 100GB.
I just wanted to ask if i do switch to the 100gb plan if unlimited data would be included in the plan anyway, or if its an error or something.
2 REPLIES 2
JadenT58
Thank you, that helps me out anyways.
HI @JadenT58
no worries, all 5G plan, except Canada-US plan, have the unlimted 512 Mbps data after the regular data being used.
If you are really worry, confirm with CS agent, please submit a ticket with CS Agent here:
