Puk code
azaygettinbandz
  • I need my puk code
1 REPLY 1
@azaygettinbandz what was the exact puk message?  there are different ones and different ways to deal with
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call  Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed",
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
If the message is "SIM network unlock PIN"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
