Puk code
Noahthomp
Where can I find my puk code.  Need it to use my sim card in a different phone
11 REPLIES 11
Noahthomp
It can't be that as it's the exact same phone that I'm trying to put it into.
I can't even find my sim card number on my account. It's not showing me the full sim ..which I apparently need to complete a ticket. I give up lol
Sarlye
@Noahthomp
I had the same issue when I tried to put my SIM card to my old unlocked Sony Ericsson candy bar phone. I got the PUK code from the manufacturer and my old provider Rogers and it wouldn’t work. The final conclusion was that the tech in the old phone was just too old and it doesn’t have enough to read the new SIM.
My brother had the same issues with an older Motorola Razor
i don’t think you mentioned what your old phone was, maybe that is the issue.
ddeep91
@Noahthomp Oh,  if you have tried the code multiple times and the  Simcard is locked then you will need to contact the mod team to get the sim unlock code.
you will need to create a ticket
To Submit a ticket, start a conversation with the Public's virtual assistant, SIMon
  • Click The "?" at the bottom right corner.
    This connects to the Autobot SImon.
  • Type "Moderator" and follow the prompts.
          (CLICK on the " Account Specific Question " and afterwards click on "No, I want a human and you will see an "Submit a ticket Click me!)
           Type a message describing the problem
OR
You can also >>>Click here<<< to connect with SImon and submit a ticket.
cheers
Noahthomp
The phone is unlocked. That's why I'm confused. Because they can't  help me. The phone is already unlocked it just won't let me use this sim without a puk code
ddeep91
@Noahthomp
If your phone is locked to bell then only bell is able to give you the  PUK code.
They ask for you the phones IMEI and they give you the  "PUK" code.
When you insert PM'S Simcard it should then ask you to enter the PUK code.
Enter the code correctly and carefully
Your Pm's sim card should start working once the phone is restarted.
Noahthomp
So it will work on my current phone but I am trying to put it into an old phone. But it won't work without this puk code. I contacted the provider to make sure the phone was unlocked and they said I needed a code from public mobile.
zblackma
You would either have to contact the previous provider or the manufacturer to get the phone unlocked. It isn't SIM locked, our you couldn't use it in your current phone @Noahthomp .
Noahthomp
I called the old provider and they explain that it was public mobile that I needed to get the puk code from. It was locked through bell. They gave a code but said it would not work until I got the puk code from public mobile. Just not sure where to get that information
ddeep91
@Noahthomp
Which provider is the phone locked to?
you will need to contact your old provider that the sim is locked to
They will give you the PUK code you can use to unlock your device.
If your phone is from Canada you will be able to get the puck code for free from them.
cheers
Triguy
Here is a previous thread with an explaination by one of the oracles, Luddite. https://productioncommunity.publicmobile.ca/t5/Getting-Started/PUK-Code/m-p/423240
