Puk code needed
07-19-2024 03:38 PM
Hello. I seemed to have locked my phone and it needs a puk code. Where do I get this?
Service
07-19-2024 03:43 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased
open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
07-19-2024 03:39 PM
@Mjb44 Get support to get the siim puk unlock code
