Puk code for another sim card
VikBond
How can to get the puk code for the SIM card for number xxxxxxx ?
slusagm
You sure you need a sim card PUK and not a device unlock code?  Why you got a new sim card locked?
For PUK for locked sim card , PM can help
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
hi @VikBond if you locked the sim, On support agent can help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
Chalupa_Batman
Firstly @VikBond Please remove your phone number from the forum. This is not private and anyone can see it. Click on the arrow in the top right corner of your post and edit.
To get the PUK code, please contact a CS Agent.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
If it is a Samsung and it requires a PUK code, contact Samsung 1-800-726-7864 for a PUK code.
