Publiic Mobile - Haida Gwaii
oliverslanding
Can I have a Public Mobile account in Masset, Haida Gwaii?
13 REPLIES 13
@nseow2001- Fair enough. Not much has changed since then though. But, sure, could have.
nseow2001
Does this work in Skidegate?  Daajing Glids?  Your answer is from 2018 so I want to check...
nseow2001
Would love to hear from someone who is currently there....
@nseow2001 wrote:
Thanks, not entirely sure I trust the coverage map...
@nseow2001   honest, you really have to try it out  🙂
Please come back and report us what you see
Remember make sure your pick Public Mobile network manually if the phone has trouble connecting.  Test on both 3G and LTE network and see if either of them connect
And the earlier replies in this 5 year old thread. Good of you to search though. Then you would need to read all the replies.
nseow2001
@nseow2001   I cannot confirm myself,
but according to the coverage map ( https://www.publicmobile.ca/en/on/coverage ) YES
nseow2001
Gwaiiguy
Can confirm, works great.
ShawnC13
I work for DND when we go there only phone on Telus/ Bell would work not Rogers . So you should be fine with PM.
wetcoaster
I think @Gwaiiguy is living in the area. Have not seen them on here for several weeks but they might be able to share their experience?
ShawnC13
I work for DND when we go there only phone on Telus would work not Rogers . So you should be fine with on
Dan
According to Telus' coverage map, yes, full LTE signal there:
https://www.telus.com/en/mobility/network/coverage-map
