@Public mobile
Lohanys
I will receive a refund because
I was charged twice.
2 REPLIES 2
@Lohanys  If you double check your credit card is one charge just pending ? If yes it should fall off but if both charges are posted then you will need to engage support for credit if owed
Public mobile prefers
you  use the orange chat bubble bottom right of screen . If that dosent work you can instead send  a  private message   To CS_Agent
