Public mobile data settings
farmbot
Recent conversations about APN settings on phones.
My Armor 9X running vanilla Android 11 shows Telus as net work and in the advanced APN setting it is all automatic with all telus and flanker brands settings available.
Interesting.
8 REPLIES 8
darlicious
@softech
Lol...no if on throttled 4G LTE data a speed test will use 6 to 10mb of data. I tested the 3G network the other evening and it used 33mb at about 10mbps. Its the full speed 4G LTE that can run thru your at upwards of 300mb to 400+mb in a single speed test.
farmbot
Other network setting to be mind full of.
4G <VoLTE>calling      Off
Wifi calling                     Off
Automatically select network     ON
Preferred network type  4G <LTE>
Android 11 has setting to receive MMS <picture> without data on   Turn ON
Phone call switch to 3G network  seemless with these settings
Ulefone working flawless first week
Cheers.
@farmbot  do not test it too many times if you don't have lots of data, if you easily drain all your data away if you just have 250Mb or 1GB data.  I think it uses 100-200MB per test.   🙂
farmbot
Publicmobile data running in parameters.
Android usually easy on APN , as long as have access to edit or create new.  The toughest one are those that hide the Edit and Add new , those you might need to use another carrier's SIM to unlock the features
farmbot
Flawless firm handshake 👌 between phone LTE and network
farmbot
I must use publicmobile APN.
Tried telus no data.
@farmbot   But your data is working without issue?
From your screenshot, while it has other Telus APN, it is still using the Public Mobile's.  So, everything working well?
