Public Points Balance Discrepancy
JL9
So my rewards/points page seems to be up and running now. When I scroll down to Recent Activity it shows points back of 1.75 for my $35 plan dated March 20th, and then shows 5 points for welcome bonus dated March 21st.
However at the top under Public Points Balance it only shows 1.75 and that is all I have to redeem. Does it just take a little extra for the 5 points they are showing to be reflected?
I guess I will check back later today to see if it has been updated.
JL9
Great thanks guys, it didn't take long at all. Just checked and it is now reflected in both spots.👍
@JL9  - It is just dated today, there may be a delay, but it does states added automatically:
SEE FAQs:
https://www.publicmobile.ca/en/ns/get-help/articles/Public-Points-FAQs
JL9
Great thanks, I figured as much. I will keep my eye out then.
Yummy
Usually sign up bonuses do not appear right away. 72 hours is what used to be max wait time for such perks.
