Public Mobile Deal Text
DAT1
I received a text as follows that I accidentally said "yes" to. How do I cancel this? The deal isn't showing on my account either
We've got a great deal for you. Get 50GB of 5G speed data for only $55/month. Reply "YES" to get this limited time offer added to your account."
maximum_gato
@DAT1
Take a screenshot before you cancel the plan change and post it so we can see the plan you were offered via text message scheduled automatically.
@DAT1  Log into your account and go to subscription add on page you will see your current plan and the upcoming plan change . And you will see option to cancel plan change like this
Cancel plan change
Umarzm1
yea i got a similar text and also no way to cancel or check its fine print. you will probably have to contact admin
Priority
How many days are left in your current billing cycle?
