Public Mobile App
sirvar
Is there a Public Mobile self serve app in the works? If not, I'd love to make a really simple one just to check your usage and other info about your plan/account. Is there an API available?
kav2001c
Public never had an app and Koodo is discontinuing their app with some absurd claim it is better to check website
Community member @IWIK created a great app for android devices.  It's called Data Witness, and it's available free for Public Mobile users in the Google Play Store.
sirvar
mimmo
The android app does monthly.  apps like my data manager does 30 and 90 day terms.
sirvar
Android also has data tracking built in but its usually 5-10mb off. Sometimes more. The self serve isnt mobile optimized either. That would also be nice
mimmo
there is no app and there likley wont be one.
not sure about the API but i doubt  it.
Most people use an app to track data like mydatanager.
