Promo Code after Registration
lilydentremont
I just registered my daughter for a new account about 10 minutes ago and noticed afterwards there is a new promo: 12MONTHS2GB, which I did not know about when I registered her.  Can I get it after the fact?  It just happened.
@lilydentremont   PM Support are usually very understanding and will try to accommodate.  Simply open a ticket with them and ask them if they can apply the promote back
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
Lovely2
@lilydentremont
 send a private message to CS_Agent  Here
them will add for you.
Meow
You should contact agent ASAP and explain you missed promo code. They could add it manually.
Send a private message to the CSA - agent by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Do not waste time with SIMon ('chat') and trying to create a ticket.
