10-14-2019 11:39 AM - edited 01-05-2022 07:33 AM
Hi - I'm trying to port my number and it seems to have partially worked....I'm getting some text messages but no phone calls. It's been about 16 hours since I started the process. I received a text saying to complete my activation, I need to go to publicmobile.ca, click Contact Us and complete the SIM & Activation Form. I can't find the "Contact Us" button. I tried going to the activation page, which I had already filled out when originally setting up, but that didn't work, I think because all my information had already been set up and I couldn't re-use the same info. To add to the frustration, I tried to submit a ticket for help and it won't let me submit a ticket either - I fill out the whole form but the Submit button stays greyed out. I tried it on 2 different browsers and a different device.
Grateful for any advice!
10-14-2019 02:43 PM - edited 10-14-2019 02:45 PM
@Dunkman wrote:You can still private message moderator directly if the ticketing process does not work. It might take a bit longer since the moderator has to confirm your identity/account. Ticketing process is a bit quicker.
I would say only to do this if the SIMon way isn't working. It's not just the verificatiom process that causes a delay, but that tickets submited through SIMon are given a higher priority.
10-14-2019 12:14 PM
It will work, but it might take a bit longer. Moderator usually take 1-2 days to respond.
You might want to try to put your old carrier SIM card in your phone for now. It might still be working.
10-14-2019 12:07 PM
Thank-you - I have tried submitting a message using the link you posted above. Hopefully it work!
10-14-2019 12:07 PM
@geopublic wrote:@alula008 You need to click on the Click me! link to submit the ticket.
Thanks, but I have tried that. I went through the whole process with Simon, clicking to submit a ticket, filling out the whole ticket form including info to verify my identity but it won't let me click the final Submit button.
10-14-2019 12:01 PM
10-14-2019 11:59 AM
10-14-2019 11:54 AM
@kav2001c wrote:The above posts are old and out of date
You should be using the Simon chat bot (question mark bottom right corner) to open a support ticket for port issues and validate your account
(To the first in posters, macros only work if you keep them up to date)
I tried submitting a ticket via Simon, but that's not working either - the Submit button stays greyed out. I tried on 2 different browsers and a different device.
10-14-2019 11:48 AM
@alula008 That text you received means that there is an issue with you port and PM will need additional info to complete the port.
You need to submit a ticket to PM and include your previous provider account number, name on the account and number.
10-14-2019 11:46 AM - edited 10-14-2019 11:46 AM
10-14-2019 11:42 AM
It looks like that you will need to contact moderator. Your port is stuck. If you are having difficulties with ticketing process, you can directly private message moderator.
Send a private message to moderator through the following link :
10-14-2019 11:41 AM
Moderator can be reached at
