Problems with activation
Shelby8
I’m having problems with activating my account, I can’t submit a ticket and the private messaging isn’t working. What do I do?
7 REPLIES 7
@Shelby8 wrote:
I cannot submit a ticket as I complete it and it won’t submit.
I can’t resolve it through chatting with the computer help and I’m about to change providers
hi @Shelby8
the link should work.  Can you try again or post a screenshot of the error
Shelby8
It is not working it brings me to a blank page. I tried uninstalling it
Shelby8
I can’t activate my E-Sim
Shelby8
slusagm
You need to open a ticket for PM to help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Sansan
The private messages always work. Delete the app and reinstall and try again.
hi @Shelby8
what is the activation issue? what error you got?
if you want to check with PM agent,  you can submit  ticket by direct message:
