Problem with eSIM
TrevorMorgan
Hello,
My eSIM module doesn't work. I want to change to physical sim card for my old phone. Could say how can I do everything correct?
Best Regards,
Maksym
TrevorMorgan
thank you so much for help
TheSterlinger
@TrevorMorgan  if you need a physical SIM you can buy one from Amazon for $4.99+ it's cheaper and quicker.
Or from a Telus Corp store for $10+. Then you'd since into your account and update the new sim card on your profile.
aip0401
Hi Maksym,
You didn't really detail what issues you're experiencing with your eSIM, but have you tried raising a Support ticket?
You can submit ticket by direct message:
