Problem with New phone number
12-14-2016 08:06 PM - edited 01-05-2022 01:20 AM
Service
12-21-2016 12:03 PM
Hi @illuty,
I'm sorry we couldn't get back to you earlier! I will sent you a private message in a little bit 🙂
12-14-2016 09:56 PM
my understaning that all the mod messages go into the same inbox. so messaging a different mod will just add to the queue.
12-14-2016 09:13 PM
12-14-2016 09:06 PM
12-14-2016 09:01 PM
OK, then you have done all you can for now. Unfortunately, it may be a few days before you have a response from the moderators.
While you are waiting try contacting tech support, by clicking this link, then "buttons" until you arrive at at webform to fill and send.
You could also try your SIM in another unlocked phone just to be sure it's not the phone acting up.
12-14-2016 08:53 PM
12-14-2016 08:39 PM
Please try your old SIM; when a port-in gets hung up it usually will continue to accept calls while you can make outgoing calls with your "temporary" number.
The second attempt to change your phone number failed because you can only change your number once per 30 days.
To clear up the problem send a private message to any moderator with your phone number and a description of what has happened, but given their backlog it will likely be several days before they respond.
For a failed port-in, they also need
- old carrier account number, exactly as shown on your bill
- old carrier phone number
- the name, exactly as shown on your bill
- an Alternate Phone Number; someone else’s, not your own
If your phone does stop working you can make phone calls with an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
